victor2022
10 questions asked 5 replies posted 10 sign-ins
Hi, friends,
    I used ModuxToobox version 3.0.0, after I setup QSPI Configurator 4.0, I still have compiling errors as "cy_serial_flash_qspi.h: No such file or directory".
   It seems that the serial-flash library has not been setup. However Usage of Quad SPI (QSPI)/Serial Memory Interface (SMIF) in PSoC™ 6 MCU (infineon.com) is under Library Manager 1.0, and I am using Library Manager 2.0, I cannot find serial-flash library under manager 2.0.
Thanks in advance.
Victor
LeoMathews
First question asked 500 replies posted 100 solutions authored
Hi @victor2022
The serial-flash library is available in Library Manager 2.0 under peripherals.
Please check the same.
Thanks and Regards,
Leo
LeoMathews
Hi @victor2022
Thanks and Regards,
Leo
victor2022
Thanks for your response. How come I don't have serial-flash under Peripheral?
Hi, this is all my library under Peripheral. As you can see that serial-flash is not in the list. Is there anyway that I can manually add serial-flash library to my Library Manager? thanks in advance.
Victor
LeoMathews
Hi @victor2022
Can you please tell which PSoC6 series device you are using? Is it a PSoC64 device?
Thanks and Regards,
Leo
LeoMathews
Hi @victor2022 ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
