YongseokJeon
Distributor - Changnam (South Korea)
50 replies posted 50 questions asked 25 replies posted
I'm testing with the example below.
- CY8CKIT-062-WIFI-BT, Dual-CPU_IPC_Semaphore
After build, the app_combined.hex file is created in the Dual-CPU_IPC_Semaphore\build\ folder. How is this created?
It seems that each hex file of M0 and M4 is created first and then merged into one file.
I checked the makefile but I don't know where the relevant information is.
Thanks and Regards,
YS
Rohan_M
50 solutions authored 25 likes received 250 sign-ins
Hi @YongseokJeon ,
Please go through to recipe_comnon.mk in path "mtb_shared\recipe-make-cat1a\release-v2.1.1\make\recipe" and go to the section "application_postbuild: $(_MTB_RECIPE__APP_HEX_FILE)" in which srec cat executable is used to combine the hex files.
You can find the srecord document in the following location "ModusToolbox\tools_3.0\srecord\docs".
Rohan
Rohan_M
Hi @YongseokJeon ,
Rohan
YongseokJeon
Hi Rohan,
Thank you very much! That was really helpful.
Thanks and Regards,
YS
