Curious on how you can apply PSoC™ 6 to Smart Home Appliances? Register for the ASEAN Smart Home Appliance Webinar here to find out how.
PSoC™ 6 Forum Discussions
yangyong
5 likes given 5 solutions authored 25 replies posted
Hi,  PSoC6  supports  centralized fault report/monitoring structures that monitor faults generated within the
device.   but i can't find fault report driver in mtb-pdl-cat1 folder.  Can you help me point out which file is the driver of the fault report. thanks!
YuZh
Moderator 10 likes received 50 sign-ins 50 replies posted
Hi:
Could you please show some examples? I can not get your idea.
zhichao
yangyong
i want to use Protection Units,  but i can't find it  in the Device Configurator or CAT1 Peripheral driver library.  how do i use this module?
YuZh
Hi:
Until now, Device configurator still did not support to config PMU. But there is an example you can find or generated by MTB based on freeRTOS.
Here is the  example link: https://github.com/cypresssemiconductorco/mtb-example-psoc6-dual-cpu-protection-units-freertos
You can refer to it.
zhichao
