shankaragurur_5
25 sign-ins 5 replies posted First reply posted
Tool: MTB 3.0
board: Psoc6 wfi/bt PROTOTYPING board
Press reset to the run the example again.
CE: emfile system
hardware : 8GB micro sdcard
SDHC enabled with MMC , write file system is working
************* emFile FAT Filesystem on SD Card and QSPI NOR Flash *************
Using SD card as storage device
Volume size: 7555072 KB
Opening the file for reading...
Unable to read. File not found.
Opening the file for writing...
File is written with the following message:
"This is an emFile filesystem example for ModusToolbox."
You can now view the file content in your PC. File name is "File.txt"
LeoMathews
First question asked 500 replies posted 100 solutions authored
Hi @shankaragurur_5
Please follow the instructions provided in the readme file to operate the code example. When the application is run for the first time, it displays that it is unable to read because the file does not exist and proceeds with writing to the file.
You need to click reset to observe reading.
Thanks and Regards,
Leo
LeoMathews
Hi @shankaragurur_5
Thanks and Regards,
Leo
LeoMathews
Hi @shankaragurur_5 ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
