I have a Vision Display graphic lcd, it uses UC1701 driver I think it supported in GUIDRV_SPage. CE223726 has an example on how to use the emWin using a different lcd. Page 6 of CE223726 doc shows how to add emWin library to PSoC Creator, I do not see this option on mine. I'm using CY8CKIT-062-BLE and have installed the complete setup for the kit.
Questions:
- Is there anything I have to install to show the graphic option?
- Does PSoC supply GUIDRV_SPage driver?
- Has anyone used this DOGS102-6 LCD? Share example codes?
I appreciate any help or pointer. Thanks.
ispn:39619:1:0
l1:314:1:0
PSoC6MCU
Hi @TJ,
I believe you should be able to see the emWin option once you have updated the Peripheral Driver Library (PDL) version. Please install the latest version of PDL from here - Peripheral Driver Library (PDL) for PSoC Creator
Rakshith M B
Hi @TJ,
The emWin library option should be available for a PSoC 6 project. Can you please share a screenshot of the Build Settings > Peripheral Driver Library?
Rakshith M B
Hi Raskshith,
Here it is:
Hi @TJ,
Rakshith M B
