Ignacio
First like received 5 questions asked 25 sign-ins
LeoMathews
First question asked 500 replies posted 100 solutions authored
Hi @Ignacio
I believe you are trying to import an existing application in ModusToolbox(BT_App as per your console message). As indicated in the console please try to import the required project by clicking on Import New Application under Quick panel.
Thanks and Regards,
Leo
Hola Leo! gracias por responder! sabrías en donde se ubican los archivos de dicho proyecto para poder eliminarlos y crear uno desde cero? el único archivo que no m deja crear es con ese nombre o relacionado a bluetooth. Tampoco me deja abrirlo importando dicha aplicación. T comento que tuve que eliminar el software y al momento de crear el proyecto con ese nombre no me deja, siendo que era el primer archivo a crear después de volver a instalar el programa.
LeoMathews
Hi @Ignacio
Can you please clarify whether you are able to create other example projects without any issue? Are you making a custom project or renaming an existing project in Project Creator? Can you please clarify on the same?
Thanks and Regards,
Leo
LeoMathews
Hi @Ignacio
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
