configuracion de Bluetooth-PSoc 6
Ignacio
First like received 5 questions asked 25 sign-ins
hola comunidad! Me podría ayudar a saber y corregir el problema del por que me salen errores en la carpeta  GeneratedSource  al momento de configurar Bluetooth. Estoy usando eclipse IDE modustoolbox 3.1
PratikshaV
100 solutions authored 5 likes given 250 sign-ins
Hi @Ignacio
This issue seems like path is too long for files so they are not able find save your project in desktop or folder which has short path
next is add these 3 files in "main.c"
#include "cycfg_gatt_db.h"
#include "cycfg_bt_settings.h"
#include "cycfg_gap.h"
open Bluetooth configurator and select your device and just save that file once
and then just build and check whether the error still persist.
I have also attached the project let me know if this helps
Thanks & Regards
Pratiksha V
PratikshaV
Hi @Ignacio
Please can you share me the detailed error message displayed? Also few questions which is this code example? Have you created new application from MTB?? configuration you are doing in Bluetooth configurator.
Thanks & Regards
Pratiksha V
hola @PratikshaV ! muchas gracias por responder, ahora adjunto lo que me pides y pregunta. Con respecto a la aplicación, elimine el software y lo instale de nuevo, cree un nuevo proyecto y aun así tengo errores en la carpeta GeneratedSource.
EJEMPLO DE CODIGO:
https://github.com/Infineon/training-modustoolbox-level3-bluetooth/blob/master/Type1/Templates/ch03_...
Ignacio
Hola @PratikshaV ! muchas gracias por responder, ahora t adjunto lo que m pides, aun sigo buscando una solución pero no la encuentro.
EJEMPLO DEL CODIGO:
cree una nueva aplicación, elimine el software, lo volví a instalar y aun así me salen los mismos errores en la carpeta GeneratedSource.
MENSAJE DE LA CONSOLA:
Initializing build: mtb-example-empty-app Debug APP_CY8CPROTO-062-4343W GCC_ARM
Prebuild operations complete
Auto-discovery in progress...
Auto-discovery complete
Commencing build operations...
Tools Directory: C:/Users/Usuario/ModusToolbox/tools_3.1
Constructing build rules...
Build rules construction complete
= Building application =
Generating compilation database file...
-> ./build/compile_commands.json
Compilation database file generation complete
Building 225 file(s)
Compiling GeneratedSource/cycfg_bt_settings.c -DCOMPONENT_4343W -DCOMPONENT_APP_CY8CPROTO_062_4343W -DCOMPONENT_CAT1 -DCOMPONENT_CAT1A -DCOMPONENT_CM0P_SLEEP -DCOMPONENT_CM4 -DCOMPONENT_CM4_0 -DCOMPONENT_Debug -DCOMPONENT_GCC_ARM -DCOMPONENT_HCI_UART -DCOMPONENT_MURATA_1DX -DCOMPONENT_MW_CAT1CM0P -DCOMPONENT_MW_CMSIS -DCOMPONENT_MW_CORE_LIB -DCOMPONENT_MW_CORE_MAKE -DCOMPONENT_MW_MTB_HAL_CAT1 -DCOMPONENT_MW_MTB_PDL_CAT1 -DCOMPONENT_MW_RECIPE_MAKE_CAT1A -DCOMPONENT_MW_RETARGET_IO -DCOMPONENT_PSOC6_02 -DCOMPONENT_SOFTFP -DCOMPONENT_WIFI_INTERFACE_SDIO -DCORE_NAME_CM4_0=1 -DCY8C624ABZI_S2D44 -DCY_APPNAME_mtb_example_empty_app -DCY_SUPPORTS_DEVICE_VALIDATION -DCY_TARGET_BOARD=APP_CY8CPROTO_062_4343W -DCY_USING_HAL -DDEBUG -DTARGET_APP_CY8CPROTO_062_4343W -Ibsps/TARGET_APP_CY8CPROTO-062-4343W -Ibsps -I. -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/bluetooth -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/config/GeneratedSource -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/config -IGeneratedSource -I../mtb_shared/retarget-io/release-v1.5.0 -I../mtb_shared/cat1cm0p/release-v1.4.0/COMPONENT_CAT1A -I../mtb_shared/cat1cm0p/release-v1.4.0 -I../mtb_shared/cmsis/release-v5.8.0/Core/Include -I../mtb_shared/cmsis/release-v5.8.0/Core -I../mtb_shared/cmsis/release-v5.8.0 -I../mtb_shared/core-lib/release-v1.4.1/include -I../mtb_shared/core-lib/release-v1.4.1 -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include/pin_packages -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A -I../mtb_shared/mtb-hal-cat1/release-v2.5.4 -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include/triggers -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/include -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/include_pvt -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/source -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0 -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A/include/ip -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party/ethernet/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party/ethernet -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party
make[1]: *** Waiting for unfinished jobs....
In file included from GeneratedSource/cycfg_bt_settings.c:27:
GeneratedSource/cycfg_bt_settings.h:30:10: fatal error: wiced_bt_cfg.h: No such file or directory
30 | #include "wiced_bt_cfg.h"
compilation terminated.
make[1]: *** [../mtb_shared/core-make/release-v3.2.2/make/core/build.mk:268: C:/Users/Usuario/mtw/proyecto/bluetooth/build/APP_CY8CPROTO-062-4343W/Debug/GeneratedSource/cycfg_bt_settings.o] Error 1
Compiling GeneratedSource/cycfg_gap.c -DCOMPONENT_4343W -DCOMPONENT_APP_CY8CPROTO_062_4343W -DCOMPONENT_CAT1 -DCOMPONENT_CAT1A -DCOMPONENT_CM0P_SLEEP -DCOMPONENT_CM4 -DCOMPONENT_CM4_0 -DCOMPONENT_Debug -DCOMPONENT_GCC_ARM -DCOMPONENT_HCI_UART -DCOMPONENT_MURATA_1DX -DCOMPONENT_MW_CAT1CM0P -DCOMPONENT_MW_CMSIS -DCOMPONENT_MW_CORE_LIB -DCOMPONENT_MW_CORE_MAKE -DCOMPONENT_MW_MTB_HAL_CAT1 -DCOMPONENT_MW_MTB_PDL_CAT1 -DCOMPONENT_MW_RECIPE_MAKE_CAT1A -DCOMPONENT_MW_RETARGET_IO -DCOMPONENT_PSOC6_02 -DCOMPONENT_SOFTFP -DCOMPONENT_WIFI_INTERFACE_SDIO -DCORE_NAME_CM4_0=1 -DCY8C624ABZI_S2D44 -DCY_APPNAME_mtb_example_empty_app -DCY_SUPPORTS_DEVICE_VALIDATION -DCY_TARGET_BOARD=APP_CY8CPROTO_062_4343W -DCY_USING_HAL -DDEBUG -DTARGET_APP_CY8CPROTO_062_4343W -Ibsps/TARGET_APP_CY8CPROTO-062-4343W -Ibsps -I. -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/bluetooth -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/config/GeneratedSource -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/config -IGeneratedSource -I../mtb_shared/retarget-io/release-v1.5.0 -I../mtb_shared/cat1cm0p/release-v1.4.0/COMPONENT_CAT1A -I../mtb_shared/cat1cm0p/release-v1.4.0 -I../mtb_shared/cmsis/release-v5.8.0/Core/Include -I../mtb_shared/cmsis/release-v5.8.0/Core -I../mtb_shared/cmsis/release-v5.8.0 -I../mtb_shared/core-lib/release-v1.4.1/include -I../mtb_shared/core-lib/release-v1.4.1 -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include/pin_packages -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A -I../mtb_shared/mtb-hal-cat1/release-v2.5.4 -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include/triggers -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/include -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/include_pvt -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/source -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0 -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A/include/ip -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party/ethernet/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party/ethernet -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party
In file included from GeneratedSource/cycfg_gap.c:27:
GeneratedSource/cycfg_gap.h:31:10: fatal error: wiced_bt_ble.h: No such file or directory
31 | #include "wiced_bt_ble.h"
make[1]: *** [../mtb_shared/core-make/release-v3.2.2/make/core/build.mk:268: C:/Users/Usuario/mtw/proyecto/bluetooth/build/APP_CY8CPROTO-062-4343W/Debug/GeneratedSource/cycfg_gap.o] Error 1
Compiling GeneratedSource/cycfg_gatt_db.c -DCOMPONENT_4343W -DCOMPONENT_APP_CY8CPROTO_062_4343W -DCOMPONENT_CAT1 -DCOMPONENT_CAT1A -DCOMPONENT_CM0P_SLEEP -DCOMPONENT_CM4 -DCOMPONENT_CM4_0 -DCOMPONENT_Debug -DCOMPONENT_GCC_ARM -DCOMPONENT_HCI_UART -DCOMPONENT_MURATA_1DX -DCOMPONENT_MW_CAT1CM0P -DCOMPONENT_MW_CMSIS -DCOMPONENT_MW_CORE_LIB -DCOMPONENT_MW_CORE_MAKE -DCOMPONENT_MW_MTB_HAL_CAT1 -DCOMPONENT_MW_MTB_PDL_CAT1 -DCOMPONENT_MW_RECIPE_MAKE_CAT1A -DCOMPONENT_MW_RETARGET_IO -DCOMPONENT_PSOC6_02 -DCOMPONENT_SOFTFP -DCOMPONENT_WIFI_INTERFACE_SDIO -DCORE_NAME_CM4_0=1 -DCY8C624ABZI_S2D44 -DCY_APPNAME_mtb_example_empty_app -DCY_SUPPORTS_DEVICE_VALIDATION -DCY_TARGET_BOARD=APP_CY8CPROTO_062_4343W -DCY_USING_HAL -DDEBUG -DTARGET_APP_CY8CPROTO_062_4343W -Ibsps/TARGET_APP_CY8CPROTO-062-4343W -Ibsps -I. -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/bluetooth -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/config/GeneratedSource -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/config -IGeneratedSource -I../mtb_shared/retarget-io/release-v1.5.0 -I../mtb_shared/cat1cm0p/release-v1.4.0/COMPONENT_CAT1A -I../mtb_shared/cat1cm0p/release-v1.4.0 -I../mtb_shared/cmsis/release-v5.8.0/Core/Include -I../mtb_shared/cmsis/release-v5.8.0/Core -I../mtb_shared/cmsis/release-v5.8.0 -I../mtb_shared/core-lib/release-v1.4.1/include -I../mtb_shared/core-lib/release-v1.4.1 -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include/pin_packages -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A -I../mtb_shared/mtb-hal-cat1/release-v2.5.4 -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include/triggers -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/include -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/include_pvt -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/source -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0 -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A/include/ip -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party/ethernet/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party/ethernet -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party
GeneratedSource/cycfg_gatt_db.c:28:10: fatal error: wiced_bt_uuid.h: No such file or directory
28 | #include "wiced_bt_uuid.h"
make[1]: *** [../mtb_shared/core-make/release-v3.2.2/make/core/build.mk:268: C:/Users/Usuario/mtw/proyecto/bluetooth/build/APP_CY8CPROTO-062-4343W/Debug/GeneratedSource/cycfg_gatt_db.o] Error 1
Compiling main.c -DCOMPONENT_4343W -DCOMPONENT_APP_CY8CPROTO_062_4343W -DCOMPONENT_CAT1 -DCOMPONENT_CAT1A -DCOMPONENT_CM0P_SLEEP -DCOMPONENT_CM4 -DCOMPONENT_CM4_0 -DCOMPONENT_Debug -DCOMPONENT_GCC_ARM -DCOMPONENT_HCI_UART -DCOMPONENT_MURATA_1DX -DCOMPONENT_MW_CAT1CM0P -DCOMPONENT_MW_CMSIS -DCOMPONENT_MW_CORE_LIB -DCOMPONENT_MW_CORE_MAKE -DCOMPONENT_MW_MTB_HAL_CAT1 -DCOMPONENT_MW_MTB_PDL_CAT1 -DCOMPONENT_MW_RECIPE_MAKE_CAT1A -DCOMPONENT_MW_RETARGET_IO -DCOMPONENT_PSOC6_02 -DCOMPONENT_SOFTFP -DCOMPONENT_WIFI_INTERFACE_SDIO -DCORE_NAME_CM4_0=1 -DCY8C624ABZI_S2D44 -DCY_APPNAME_mtb_example_empty_app -DCY_SUPPORTS_DEVICE_VALIDATION -DCY_TARGET_BOARD=APP_CY8CPROTO_062_4343W -DCY_USING_HAL -DDEBUG -DTARGET_APP_CY8CPROTO_062_4343W -Ibsps/TARGET_APP_CY8CPROTO-062-4343W -Ibsps -I. -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/bluetooth -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/config/GeneratedSource -Ibsps/TARGET_APP_CY8CPROTO-062-4343W/config -IGeneratedSource -I../mtb_shared/retarget-io/release-v1.5.0 -I../mtb_shared/cat1cm0p/release-v1.4.0/COMPONENT_CAT1A -I../mtb_shared/cat1cm0p/release-v1.4.0 -I../mtb_shared/cmsis/release-v5.8.0/Core/Include -I../mtb_shared/cmsis/release-v5.8.0/Core -I../mtb_shared/cmsis/release-v5.8.0 -I../mtb_shared/core-lib/release-v1.4.1/include -I../mtb_shared/core-lib/release-v1.4.1 -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include/pin_packages -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A -I../mtb_shared/mtb-hal-cat1/release-v2.5.4 -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/COMPONENT_CAT1A/include/triggers -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/include -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/include_pvt -I../mtb_shared/mtb-hal-cat1/release-v2.5.4/source -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0 -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/devices/COMPONENT_CAT1A/include/ip -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party/ethernet/include -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party/ethernet -I../mtb_shared/mtb-pdl-cat1/release-v3.9.0/drivers/third_party
make: *** [../mtb_shared/core-make/release-v3.2.2/make/core/main.mk:374: secondstage_build] Error 2
In file included from main.c:50:
make[1]: *** [../mtb_shared/core-make/release-v3.2.2/make/core/build.mk:268: C:/Users/Usuario/mtw/proyecto/bluetooth/build/APP_CY8CPROTO-062-4343W/Debug/main.o] Error 1
"C:/Users/Usuario/ModusToolbox/tools_3.1/modus-shell/bin/make CY_MAKE_IDE=eclipse CY_IDE_TOOLS_DIR=C:/Users/Usuario/ModusToolbox/tools_3.1 CY_IDE_BT_TOOLS_DIR= --output-sync -j8 all" terminated with exit code 2. Build might be incomplete.
20:57:48 Build Failed. 10 errors, 0 warnings. (took 26s.566ms)
PratikshaV
Hi @Ignacio
Thanks & Regards
Pratiksha V
Ignacio
hola! @PratikshaV! por supuesto que me sirvió tu ayuda! a partir del proyecto ch03_ex01_ble.zip que compartiste me pude guiar, y el problema era que no había agregado la librería "btstack-integration".Esta librería incluye a
"cycfg_gap.h"
"cycfg_gatt_db.h".
Muchas Gracias!!
