niDa_3035361
i am working with capsense board and i have communicated my development board with capsense board .
i did all the connection and i have written capsense slave address into my code  also set clock frequency  at 100kHz.
but capsense board does not given any ACK from their side. i have also check SDA and SCL data  on oscilloscope. it is right but still board not giving any ACK
please guide me if you have any suggestion.
himam_31
Kindly attach your project.
Hima
hi Hima
just i want to know how the SCL and SDL pin connection of capsense board for communcation with any devlopment board of SCL and SDL pins.
also i am attaching my code below for the capsense board.
Could you please tell us which PSoC kit and which CapSense board you are using. Have you written your own firmware or used a code example?
Your last post does not have any attachment.
Could you also try and use the bridge control panel to communicate with the capsense board. The bridge control panel acts as an I2C master. You can use this to verify if your slave is operating correctly
