SaGa_4641021
Level 4
Level 4
50 replies posted 100 sign-ins 50 sign-ins
Hi
I am using the SPI as slave with external interrupt source.
The ISR does not return even if I clear the RxBuffer:
Cy_SCB_SPI_ClearRxFifo(sSPI_HW);
Cy_SCB_SPI_ClearRxFifoStatus(sSPI_HW, CY_SCB_SPI_RX_INTR_MASK); //CY_SCB_SPI_RX_NOT_EMPTY);
how should I properly clear the interrupt for the SPI ?
thanks
Hari
Hi @SaGa_4641021
Please make sure that you are calling the Cy_SCB_SPI_Interrupt  API inside the user-defined ISR. You can take a look at the PDL documentation or the PSoC 4 Code example that uses the PDL functions for SPI transactions.
Hari
Hari
Hi @SaGa_4641021
Hari
