Post-build commands for Cortex-M4 core
E:\Work\19.Watch\Software\cy8c62-V0.001\Workspace05 - test\App1\Watch001.cydsn>"C:\Program Files (x86)\Cypress\PDL\3.1.0""\tools\win\elf\cymcuelftool.exe" -M .\CortexM4\ARM_GCC_541\Debug\Watch001.elf ..\App0.elf -- output
--: Failed to open --
E:\Work\19.Watch\Software\cy8c62-V0.001\Workspace05 - test\App1\Watch001.cydsn>.\CortexM4\ARM_GCC_541\Debug\Watch001_merged.elf --hex
'.\CortexM4\ARM_GCC_541\Debug\Watch001_merged.elf' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
E:\Work\19.Watch\Software\cy8c62-V0.001\Workspace05 - test\App1\Watch001.cydsn>.\CortexM4\ARM_GCC_541\Debug\Watch001.hex
--------------- Build Succeeded: 01/08/2020 15:06:08 ---------------
按照步骤配置了,编译后没有合并成功。
这个是app1的.bat文件:
@rem Set proper path to your PDL 3.x and above installation
@set PDL_PATH="C:\Program Files (x86)\Cypress\PDL\3.1.0"
@set CY_MCU_ELF_TOOL=%PDL_PATH%"\tools\win\elf\cymcuelftool.exe"
@set IDE=%1
@if "%IDE%" == "creator" (
@set OUTPUT_DIR=%2
@set PRJ_NAME=%3
@set ELF_EXT=.elf
@if "%IDE%" == "uvision" (
@set OUTPUT_DIR=%2
@set PRJ_NAME=%3
@set ELF_EXT=.axf
@if "%IDE%" == "iar" (
@set OUTPUT_DIR=%2
@set PRJ_NAME=%3
@set ELF_EXT=.out
@if "%IDE%" == "eclipse" (
@set OUTPUT_DIR=%2
@set PRJ_NAME=%3
@set ELF_EXT=
@rem Merges App0 and App1 into a single hex file for easier programming
%CY_MCU_ELF_TOOL% -M %OUTPUT_DIR%\%PRJ_NAME%%ELF_EXT% ..\App0%ELF_EXT% -- output
%OUTPUT_DIR%\%PRJ_NAME%_merged%ELF_EXT% --hex
%OUTPUT_DIR%\%PRJ_NAME%.hex
所附的bat文件最后hex merge的命令看上去有点问题,-- output应改为--output,中间没有空格。应该添加的全部命令行,如下参考,可以重新试一下 -
%CY_MCU_ELF_TOOL% -M %OUTPUT_DIR%\%PRJ_NAME%%ELF_EXT% ..\App0%ELF_EXT% --output %OUTPUT_DIR%\%PRJ_NAME%_merged%ELF_EXT% --hex %OUTPUT_DIR%\%PRJ_NAME%.hex
