PSoC™ 6 Forum Discussions
Tim_Shih
50 replies posted 50 questions asked 100 sign-ins
Dear Receiver,
In the MTB, I only see "import" and "export" a whole project. A project is not equal to a BSP.
So I feel curious about how to import a BSP from others or export my own BSP to others ?!
Thank you so much.
yangyong
5 likes given 5 solutions authored 25 replies posted
There are two methods to import BSP.
The first, when you are building new application, open project creator, you can import your BSP.
the second, in the application you have built, In the Makefile, you set the value of the TARGET make variable to match your  BSP.
as for export BSP,  BSP  is a set of files  and is  stored in the application's libs directory by default,you can copy it to your application's folder.
yangyong
Tim_Shih
Hi ~ Yoya,
Thank you for your feedback.
Could you please give me a sample bsp to try ?!
I propably know what you said but I need to operate it one time.
Thank you so much.
yangyong
when you create one   ModusToolbox applications,  BSPs that are local to the application are located in the libs subdirectory, while shared BSPs are located in the mtb_shared directory adjacent to the application directory.
