Tyler1
Distributor - UNIQUEST
First reply posted 5 questions asked 50 sign-ins
Hi, I would like to use the wifi scan app created in Modustoolbox with Zephyr OS. Is there any guide or sample example available for this? Should I use the API of the driver located at "zephyrproject/modules/hal/infineon/wifi-host-driver"? The module I am using is CY8PROTO-062-4343W.
Aditi_B
500 replies posted 5 questions asked 250 replies posted
Aditi_B
I'll check with the internal team and will revert back.
Aditi
Aditi_B
Please check out the following Application Note that provides the steps to create modules and debug applications in ModusToolbox-
https://www.infineon.com/dgdl/Infineon-AN236472_-_Zephyr_RTOS_Creating_modules_and_debugging_applica...
FYI-
https://www.infineon.com/cms/en/design-support/software/zephyr/#
https://github.com/Infineon/zephyr-1?tab=readme-ov-file
Aditi
