May 06, 2021
03:41 AM
May 06, 2021
03:41 AM
Dear Cyprerss/Infineon Support,
Wrong configuration for TX-Enable pin (RS-485 Support) is generated using the Device Configurator 3.0.
I had a problem using the configuration generated with that tool. If I select a TX-Enable pin it generates a configuration like this:
#ifndef ioss_0_port_3_pin_3_HSIOM
#define ioss_0_port_3_pin_3_HSIOM HSIOM_SEL_GPIO
#endif
But it must be like this to have a signal coming from CTS pin:
#define ioss_0_port_3_pin_3_HSIOM HSIOM_SEL_ACT_6
#endif
Gintaras
Labels
PSoC 6 MCU
03:38 AM
May 07, 2021
03:38 AM
Hi @Gintaras,
Our internal team is looking into your query.
The updates would be posted here.
Thanks and regards,
Nikhil
