No_Name
25 sign-ins 10 likes given 5 questions asked
I'm trying to make Wi-Fi enterprise connection with TP-LINK router using radius server but, while connecting I'm getting error as MBEDTLS_SSL_ALERT_MSG_BAD_CERT at the time of parsing server certificate.
Same scenario I tested with Cisco router then there is no error. Able to connect successfully.
FYI: Using  CYW43455 chip as Wi-Fi module
TP-link model no: Archer MR200
Cisco Model no: Linksys E900
PRI
100 replies posted 5 likes given 10 likes received
Please provide info for my below questions.
1. Which SDK you're using (WICED or MTB with ver)?
2. What is the host MCU?
3. Are you using FreeRadius? If so, what is the version?
No_Name
SDK: WICED-Studio-6.6
Host MCU: i.MX RT1051
Yes, I'm using FreeRadius.
Version : 3.0
PRI
Are you using WICED only or MCUXpresso by porting WICED stack to it? Asking this as i.MX by default doesn't have support in WICED. Host is interfaced with WLAN through SDIO only right?
No_Name
Host is interfaced with WLAN through SDIO only right yes correct.
Not using MCUXpresso ide. Using Eclipse ide as per project requirement code is there.
But, WICED stack no change.
No_Name
Any update?
PRI
The error message points to server certificate being not proper so please make sure you've configured the server certificate correctly on the Free Radius side. Apart from this, you can provide the terminal logs after uncommenting "supplicant stack prints" in "wiced_defaults.h" file.
Also, please provide the wireshark logs containing the TLS exchanges between your device and AP.
No_Name
I know the error message is regarding certificate. But, same certificate when I'm using with Cisco router it's working fine.
Regarding Wireshark logs  I'll send you as soon as possible .
No_Name
Sorry for late reply.
Please check Wireshark logs & radius server logs.
No_Name
Any update on Wi-Fi enterprise issue.
PRI
The wireshark logs you've attached doesn't have TLS interactions between 43455 & AP. I believe you've captured the logs on windows machine using wireshark. I would want to see the certificate in wireshark logs for both the cases (success and failure).
No_Name
Can you please try using radius filter in Wireshark.
I think network logs are mixed.
PRI
I can see Radius packets in the logs but they are not helpful to understand the failure. As I've mentioned before, TLS packets will have server certificate and will give some clue on whether the server certificate is correctly sent to the 43455 from the AP.
TorshaDas
First reply posted Welcome!
Could you please tell how to get those TLS packets so that we could provide you with the information u are looking for
PRI
There are two modes of sniffing - Native, Monitor. In monitor mode, you can capture packets from all devices on any network. In native mode, you can only capture packets between your PC and router. Linux, Mac PCs support monitor mode usually so you can run wireshark on them and capture logs. You can do it on your windows machine if your wifi card supports monitor mode to capture TLS packets between 43455 & AP.
