I have setup a PSOC6 project using CY8CKIT-062-WiFi-BT as my device. I have configured a digital PIN and assigned P0_3 to it. P0_3 maps to RED LED in RGB from schematics. I am able to blink the LED when used in for loop but not outside of it.
In main_cm4.c,
The following is working:
for(;;)
Cy_GPIO_Write(LED_R_PORT, LED_R_NUM, 1);
CyDelay(500);
Cy_GPIO_Write(LED_R_PORT, LED_R_NUM, 0);
CyDelay(500);
But this is not turning the LED on.
for(;;)
Why?
The GPIO is configured as Digital output with no hardware connection. The initial drive state is low.
Dheeraj
All the user LEDs are active low, so a Cy_GPIO_Write(LED_R_PORT, LED_R_NUM, 0); will turn it on.
Bob
Bob
Oh okay. I didn't find active low symbol in the schematics. Can you point me to the docs where this information is present?
Dheeraj
When you installed the CY8CKIT-062 correctly there will be an entry for the complete description in C:\Program Files(x86)\Cypress\...
When you follow the ...\Hardware\... path there you will find a schematics PDF. Search for "user LED"
Happy coding
Bob
