Dear Sir ~
As in the attached file, I can't find any sample codes in this page.
For example,,,
If I want to initialize SPI master function in this kit, how can I start ?! (I don't have base code to develop!!)
Thank you so much.
PSoC 6 MCU
Hi @Tim_Shih,
Yes, the sample codes are not available on the product page. You can refer to ‘PSoC 6 MCU Code Examples for ModusToolbox Software’ page for code example or you can directly open the code examples from ModusToolbox IDE. Kindly follow these steps to open the code example in ModusToolbox IDE.
- Open ModusToolbox 2.4 IDE.
- Click on File > New > ModusToolbox Application
- Select the appropriate device and press next. In your case, it will be CY8CKIT-062S2-43012
- In the select application menu, either you can search for SPI Master or go to peripherals and then click on SPI Master application.
Please, let me know if you need further clarification.
Best Regards
Raj Chaudhari
Hi @Tim_Shih,
Best Regards
Raj Chaudhari
ok ok, Thank you. Thank you.
But I have another question.
Now this SPI Master sample code is based on traditional program process.
If I want to convert this kind of traditional program to become RTOS based program.
What should I do ?!
Do you have any related application notes for us to refer ?!
Thank you so much !!!
Hi @Tim_Shih,
You can refer to this "Interfacing DHT-11 with PSoC 6 using ModusToolBox 2.1" ModusToolbox blog for converting traditional program to RTOS based program.
Let me know if further clarification is required.
Thank you
Best Regards
Raj Chaudhari
