WDT interrupt not triggered on CM0+
vinu_gk
50 sign-ins First solution authored 10 replies posted
I want to run watchdog timer in interrupt mode in PSOC 6 CM0+ core. I referred and copied the CM4 WDT examples and ported the code for CM0 core. However, i am unable to WDT interrupt or MCWDT interrupt.
I even tried the WDT workaround below, but of no success:
Workaround for PSoC 6 MCU Device ILO Start Failure in PSoC Creator 4.2 – KBA229046
Please note that i am using :
  • CY8CKIT-062-WiFi-BT PSoC 6 WiFi-BT Pioneer Kit 1.0 Rev.**
  • Peripheral Driver Library 3.0.1
  • PSoC Creator 4.2
best regards,
Vinu
Hari
Hi @vinu_gk
You need to configure the interrupts for the CM0p core with an additional cm0psource as well.
const cy_stc_sysint_t mcwdt_int_cfg = {
    .intrsrc=(IRQn_Type) NvicMux7_IRQn,
    .cm0psrc=srss_interrupt_mcwdt_0_IRQn,
    .intrPriority = 2
I am attaching a sample code that shows MCWDT interrupt with CM0p. Please try this and let me know if you have any further queries.
Hari
Hari
Hi @vinu_gk
    .intrPriority = 2
Hari
vinu_gk
Thanks Hari. I will check it and update you.
BTW, i found these defines in cyfitter_sysint_config.c file. Can we make use of these defines ?
regards,
Vinu
Hari
Hi @vinu_gk
You can make use of similar interrupt config structures. The main.c attached in my previous response shows a similar approach in defining the WDT interrupts.
Hari
vinu_gk
Hi Hari,
The WDT interrupt triggered when i commented the following line in main_cm0p.c :
Cy_SysEnableCM4(CY_CORTEX_M4_APPL_ADDR);
I couldn't figure out the reason. Can you please check what i am missing here ?
regards,
Vinu
Hari
Hi @vinu_gk
That line enables the CM4 core for execution. Commenting that line of code prevents the CM4 from starting and the PSoC device works as a single core device.
You would still need to configure the interrupts correctly for the WDT to trigger in CM0p. Can you please share your project so that I can take a look?
Hari
vinu_gk
Hi @Hari ,
I think MCWDT interrupt worked when i added this line :
NVIC_ClearPendingIRQ((IRQn_Type) VALVE_MCWDT_ISR_cfg.intrSrc);
thanks!
vinu_gk
Hi Hari,
Please see the attached project. The red LED blinks every 1 second using WDT interrupt.
regards,
Vinu
