carrino
10 sign-ins 5 replies posted First reply posted
I have found conflicting information.
From PDL: https://infineon.github.io/psoc6pdl/pdl_api_reference_manual/html/group__group__sysclk__wco.html?fbc...
The WCO can also be used in bypass mode, where an external 32.768 kHz square wave is brought in directly through the SRSS_WCO_OUT_PIN pin.
from AN218241  PSoC™ 6 MCU hardware design considerationshttps://documentation.infineon.com/html/psoc6/kwz1667482930244.html
In addition, the WCO block can be bypassed altogether and a 32.768-kHz external sine wave can be directly fed to the WCO_OUT pin. In this configuration, the WCO_IN pin should be left floating. To bypass the WCO using PSoC Creator, enable WCO in Configure System clocks window and set the Clock port radio button in the Configure WCO dialog box to Bypass (External sine wave) as shown in Figure 11. In ModusToolbox, enable WCO in the Device Configurator (design.modus) and set the Clock Port to Bypass (External sine wave) as shown in Figure 12. This will configure the WCO block to route a 32.768-kHz clock (sine wave signal) on WCO_OUT pin to RTC and LFCLK. Make sure that the WCO_IN pin is not used and left floating in the design.
Arpit_S
50 likes received 250 replies posted 100 solutions authored
Hi @carrino , @Rodo , @euggersh ,
The signal can either be Square Wave or Sine Wave.
Thanks!
Kind regards
Arpit Srivastav
Arpit_S
Hi @carrino
Can you please help me in pointing out the conflicting info that you have found? I am not able to pin point it.
Thanks!
Kind Regards
Arpit Srivastav
Rodo
10 likes given 100 sign-ins 5 solutions authored
Maybe this picture will make it easier to see the discrepancy.WCOsineORsquare.png
carrino
Sine vs Square wave.
carrino
I have a square wave external oscillator that I want to use, but everything says sine wave, except that one place in the PDL that says square wave.
And at the very bottom of AN218241 where it says
Is the external 32.768-kHz square wave clock connected to WCO_OUT pin and WCO_IN left floating?
euggersh
Level 5
Level 5
5 sign-ins First solution authored 50 replies posted
@Arpit_S, will anybody from Infineon be following up to clarify this documentation inconsistency?
Arpit_S
Thanks!
Kind regards
Arpit Srivastav
Rodo
@Arpit_S Could you be more specific about the sinewave. A sinewave could be bipolar (positive and negative). Is that ok? Thanks.
Arpit_S
Hi @Rodo ,
The peak values of this sine wave are limited to -Vd and VDD+Vd, where Vd is the forward biasing voltage of the ESD body diodes (about 0.6V) and VDD is the supply voltage.
Thanks!
Kind regards
Arpit Srivastav
