We are trying to use hard FPU in PSoC 6, but in core_cm4.h FPU requires setting __SOFTFP__ into 0u:
however, it seems PSoC creator is using soft FPU by default:
In this thread, GeonaM_26 has explained how to make new Makefile to change softfp into hardfp:https://community.cypress.com/thread/32197?q=Using%20hard%20FPU
but, this requires compiling the whole project outside of PSoC creator. Is there any way to change this parameter without manipulating a Makefile?
You can use the ModusToolbox tool instead of PSoC Creator. That configuration can easily be changed in a Eclipse based environment.
However, the tool does not support UDBs yet, in case you are using it.
It seems we need to eventually switch to Modus ToolBox ; however, we actually do use UDB in our project. Do I have to use arm gnu toolchain to compile the make file? I have tried it and it is giving me errors at time of make:
Export/prebuildCortexM0p.sh
make (e=-1): Error -1
make: *** [prebuild_CortexM0p] Error -1
Ensure that you follow the steps in enabling hardfp psoc 6
Could you share the PSoC Creator project to recreate the issue at our end?
