Ken_Zhang
Distributor - Zenitron(GC)
25 sign-ins 5 questions asked 10 sign-ins
Dear
I use Modus offline version to build https://github.com/infineon/training-modustoolbox-level3-wifi/project/key_ch04b_05_httpbin, it shows " fatal error: core_pkcs11.h, thansport_interface.h ,no such file or directory".
I check mtb_share/aws-iot-device-sdk-embedded-C/ or/aws-iot-device-sdk-port/ concent,  no the error *.h file, so Could you update them when release the Modus offline version?
Charles_Lai
250 sign-ins 10 likes given 10 questions asked
How to run " git submodule update --init --recursive"? use modus-shell tool?
Yes, in modus-shell, locate the repo and run the command.
And I copy a new " aws-iot-device-sdk-embedded-C.zip " package from other guys, maybe it is downloaded online version, unzip and replace it in my "mtw2.4\mtb_shared\aws-iot-device-sdk-embedded-C\202103.00, it can resolve my issue.
Sure. It's equivalent to the command.
So do your team also do it before releasing the new offline modus version?
We can't do this for you. It's not part of the offline content package mechanism because submodules are submodules. It's off the limits. You can only manually fix this.
Roy_Liu
First comment on KBA 10 questions asked First comment on blog
Hi Ken,
May you have a try with the online version Modus using the method by a community contributor here https://community.infineon.com/t5/Code-Examples/ModusToolbox-URL-Modifier/td-p/366015
Roy Liu
Ken_Zhang
Dear Roy
Sorry, I must use modus offline version, can you other method to reslove it?
Roy_Liu
No problem Ken, I mentioned the online version is just an option for you, if you have to use the offline,  we may also help to check, but frankly, I am not sure how soon and if can be fixed once for all with the offline version.
Roy Liu
Charles_Lai
AWS-IoT-related middleware has submodules, which can't be cached by offline content package for now. So you would see this error for sure.
Meanwhile, your issue can't be easily resolved if you insist on using the offline content package. In this case, You have to manually initiate the submodules using the below command (which also requires network connections):
This is documented in the instructions of aws-iot-device-sdk-embedded-C and aws-iot-device-sdk-port:
https://github.com/aws/aws-iot-device-sdk-embedded-C
Ken_Zhang
Dear Charles
And I copy a new " aws-iot-device-sdk-embedded-C.zip " package  from other guys, maybe it is downloaded online version , unzip  and replace it in my "mtw2.4\mtb_shared\aws-iot-device-sdk-embedded-C\202103.00, it can reslove my issue.
So do your team also do it before release the new offline modus version?
Charles_Lai
