raya_4824241
10 sign-ins 5 sign-ins First like received
Is it possible to use the CY8KIT-028-EPD shield instead of the CY8CKIT-028-TFT for doing the Machine Learning Gesture Classification example?  They both use the BMI160 IMU, but the example doesn't seem to work with the EPD shield.
RodolfoGL
250 sign-ins 5 comments on KBA First comment on KBA
The example works with the CY8CKIT-028-EPD as well. You can keep the "SHIELD_DATA_COLLECTION" set to TFT shield, since both shields have the same sensor and placed in the same I2C pins.
RodolfoGL
