PSoC™ 6 Forum Discussions
MiKi_3184011
First like given
I am able to list the sensor and receive correct response using CY8CKIT-062-WiFi-BT, however when i change to CY8CPROTO-062-4343W and wire exactly the same i do not see sensor in list?
Vison_Zhang
250 solutions authored 10 likes given 500 replies posted
Could you share your project?
MiKi_3184011
First like given
It is not related to any project, the problem is trying to communicate over I2C using the Bridge Control Panel.  When connected to a sensor on the CY8CKIT-062-WIFI-BT board a "list" command properly returns the sensor address's.  However when i connect the sensor exactly the same way(SCL @ 6.0, SDA @ 6.1) to the CY8PROTO-062-4343W board it does not work, or see the sensor.....
CY8CKIT-062-WIFI-BT:
CY8PROTO-062-4343W
I don't have a I2C sensor, so i programmed an EZI2C demo project into P6 devices to do the test use BCP, i can read I2C address by using both DVKs
My test ModusToolsBox project and final elf file is attached(CY8CPROTO-062-4343W).  If you still cannot find the i2c address use BCP, please check the resistor R15, R16 is exist on your CY8CPROTO-062-4343W board or not, they are pulled up resistors.
