Unable to run gesture-classification example
jayesh_joshi
Level 4
Level 4
50 replies posted 10 questions asked 25 sign-ins
I am trying to run a gesture classification demo on the CY8CKIT-062S2-43012 kit. I am following the steps described in https://github.com/Infineon/mtb-example-ml-gesture-classification.
But as try to import the example using New Application link in the Quick Panel I run into the below error and can not download the example. I have tried both methods described in the https://community.infineon.com/t5/Code-Examples/ModusToolbox-URL-Modifier/td-p/366015 thread but still running into the same issue.
Loading the manifest data
Found environment variable CyRemoteManifestOverride=https://raw.githubusercontent.com/Infineon/mtb-super-manifest/v2.X/mtb-super-manifest-fv2.xml
Loading super manfiest files from all sources
Processing manifest pack file 'C:/Infineon/Tools/ModusToolbox/packs/ModusToolbox-Machine-Learning-Pack/manifest.xml'
Downloading super manifest file 'file:///C:/Infineon/Tools/ModusToolbox/packs/ModusToolbox-Machine-Learning-Pack/manifest.xml'
Getting manifests from remote and/or local sources
Processing system manifest 'https://raw.githubusercontent.com/Infineon/mtb-super-manifest/v2.X/mtb-super-manifest-fv2.xml'
Downloading super manifest file 'https://raw.githubusercontent.com/Infineon/mtb-super-manifest/v2.X/mtb-super-manifest-fv2.xml'
Finished loading super manifest files from all sources
Finished download of file 'file:///C:/Infineon/Tools/ModusToolbox/packs/ModusToolbox-Machine-Learning-Pack/manifest.xml'
Starting to parse super manifest with URL 'file:///C:/Infineon/Tools/ModusToolbox/packs/ModusToolbox-Machine-Learning-Pack/manifest.xml'
Finished parsing super manifest with URL 'file:///C:/Infineon/Tools/ModusToolbox/packs/ModusToolbox-Machine-Learning-Pack/manifest.xml'
Downloading manifest file 'file:///C:/Infineon/Tools/ModusToolbox/packs/ModusToolbox-Machine-Learning-Pack/manifests/mtb-ml-ce-manifest.xml'
Finished download of file 'https://raw.githubusercontent.com/Infineon/mtb-super-manifest/v2.X/mtb-super-manifest-fv2.xml'
Finished download of file 'file:///C:/Infineon/Tools/ModusToolbox/packs/ModusToolbox-Machine-Learning-Pack/manifests/mtb-ml-ce-manifest.xml'
Finished loading the manifest data (42454 ms)
Loading the device db
INFO:Using the executable path for the tools directory.
WARNING:Error downloading 'https://raw.githubusercontent.com/Infineon/mtb-super-manifest/v2.X/mtb-super-manifest-fv2.xml' -- Connection timed out
INFO:No device-db assets found in manifest
0 error(s), 1 warning(s
git bash config after modifying the URL as suggested.
core.editor="C:\\Program Files (x86)\\Notepad++\\notepad++.exe" -multiInst -notabbar -nosession -noPlugin
pull.rebase=false
credential.helper=manager
credential.https://dev.azure.com.usehttppath=true
init.defaultbranch=master
url.https://ghproxy.com/https://github.com.insteadof=https://github.com
Let me know if I am missing something.
LeoMathews
First question asked 500 replies posted 100 solutions authored
Hi @jayesh_joshi
Can you please check whether you have a .modustoolbox folder in your C:/  folder? If yes, can you please set a new system environment variable CY_GETLIBS_GLOBAL_PATH = C:/.modustoolbox/global and restart ModusToolbox?
I believe you have installed ModusToolbox in a custom location. For ModusToolbox version 3.0, a global path for assets like device-db using the variable CY_GETLIBS_GLOBAL_PATH should also be included if the .modustoolbox folder is in a non-default location. If the variable does not exist, it assumes a default path of ~/.modustoolbox/global.
After setting the new variable and restarting MTB, please try to create the project again and let me know if the issue persists.
Thanks and Regards,
Leo
LeoMathews
Hi @jayesh_joshi
Thanks and Regards,
Leo
jayesh_joshi
Level 4
Level 4
Thank you @LeoMathews  for the response.
There is no .modustoolbox folder in C:/  but the modus toolbox is installed at C:\Infineon\Tools.
So based on that, I have created the environment variable CY_GETLIBS_GLOBAL_PATH = C:/Infineon/Tools/ModusToolbox/global. Please find the below image for reference.
But still running into same issue.
LeoMathews
Hi @jayesh_joshi
The folder .modustoolbox is different from the ModusToolbox folder. Can you please check if there is a .modustoolbox folder in C:/users/<username>  path?
Thanks and Regards,
Leo
jayesh_joshi
Level 4
Level 4
@LeoMathews
I have been able to make it work after 2-3 uninstall/install cycles.  One of the things I missed was that script attached in https://community.infineon.com/t5/Code-Examples/ModusToolbox-URL-Modifier/td-p/366015 was not successful due to the execution policy. Once I set the execution policy to the unrestricted script was successful.
