I have USB CDC enabled in my PSoC 62 application and bootloader. When I switch from the application to the bootloader using the function Cy_Bootload_ExecuteApp(0), USB will not enumerate after the bootloader starts. The device manager shows Unknown USB Device (Device Descriptor Request Failed). Before calling Cy_Bootload_ExecuteApp(0) I call USBFS_Stop() and delayed 10s before starting bootloader and I still see this problem. The USB device disappears from the PC device manager 2s after I call USBFS_Stop(). When the bootloader starts running, I see the Unknown USB Device error even before I initialized USB so I think USBFS_Stop() is not enough to reset the USB state on the PSoC. What else do I need to do in the application or bootloader to allow USB to work across app switch to bootloader?
I am using PSoC Creator and beta USB driver. I switched to final driver from PDL 3.1.0 and it works. Thanks.
Hello ,
Can you please attach your project? Are you using Modus or PSoC Creator for creating the project?
Hima
