UART smartcard mode echo
PSOC6_dev
Level 4
Level 4
10 questions asked 25 sign-ins 25 replies posted
Hi all,
I've a little question about the way UART works on PSOC6.
My project is on ModusToolBox and I use only low level API for UART (smartcard mode) (Cy_SCB_UART_Put() /  Cy_SCB_UART_Get()).
Each time i send a byte, i have the echo and need to read this bytes to empty rx fifo.
Is it normal ? is it possible to avoid this ?
Thank you for your support,
wisc_ece353
10 replies posted First question asked 10 sign-ins
I do not think you should be getting an echo on the Rx FIFO when you use the Cy_SCB_UART_Put() API.
This could be a good starting point for UART low level APIs - https://github.com/Infineon/Code-Examples-for-the-ModusToolbox-PSoC-6-SDK/blob/mt1.1/CE219656_PSoC6_...
Can you try this out and let us know if it works? Please attach your project if possible so that we can have a look.
Hi, Thank you for your response,
It's not the same usage. I use uart as smartcard mode (rx/tx on the same line)
PSOC6_dev
Level 4
Level 4
Anyone experienced UART smartcard mode ?
PSOC6_dev
Level 4
Level 4
Infineon team ?
PSOC6_dev
Level 4
Level 4
Hello ?😞
PSOC6_dev
Level 4
Level 4
1 month without any reaction, should I flag it as a non-solution ? 🙂
