Hi all,
I am using the PSoC 6 cy8ckit-064b0s2-4343w . I attempted to construct a UART interrupt in Modustoolbox (version 3.0)using SCB blocks without FreeRTOS, and the hardware interrupt happened at that time. However, when I implemented the same code again with FreeRTOS(v10.4.302), I did not encounter a hardware interrupt since FreeRTOS does not call the interrupt function while transmitting.
The PDL(v3.2.0) API's used:
For configuration:
(void) Cy_SCB_UART_Init(SCB5, &uartConfig, &uartContext)
Cy_GPIO_SetHSIOM(UART_PORT, UART_RX_NUM, P5_0_SCB5_UART_RX)
Cy_GPIO_SetDrivemode(UART_PORT, UART_RX_NUM, CY_GPIO_DM_HIGHZ)
For transmit data:
(void) Cy_SCB_UART_Transmit(SCB5, txBuffer, sizeof(txBuffer) and &uartContext)
For enable Interrupt:
(void) Cy_SysInt_Init(&uartIntrConfig, &UART_Isr) and NVIC_EnableIRQ(UART_INTR_NUM)
For other API's I referred https://infineon.github.io/psoc6pdl/pdl_api_reference_manual/html/group__group__scb__uart.html . Can anyone suggest why in FreeRTOS the same code I implemented without FreeRTOS is not working and does I have to include any PDL API for interrupt in FreeRTOS?
Hi @pblemel ,
Please refer the below example for UART Tx and Rx interrupt with FreeRTOS.
#include "cy_pdl.h"
#include "cyhal.h"
#include "cybsp.h"
#include "FreeRTOS.h"
#include "task.h"
#include <stdio.h>
#include <string.h>
* Macros
#define UART_TASK_STACK_SIZE (1024*10)
#define UART_TASK_PRIORITY (configMAX_PRIORITIES - 3)
#define DEBUG_UART_HW SCB5
#define DEBUG_UART_IRQ scb_5_interrupt_IRQn
* Function Prototypes
* Global Variables
/* This enables RTOS aware debugging. */
volatile int uxTopUsedPriority;
cy_stc_scb_uart_context_t uart_context;
char txBuffer[100];
char rxBuffer[5];
int txcounter = 0;
int rxcounter = 0;
void UART_Isr(void)
Cy_SCB_UART_Interrupt(DEBUG_UART_HW, &uart_context);
void HandleEventsUart(uint32 event)
if((event & CY_SCB_TX_INTR_LEVEL ) == CY_SCB_TX_INTR_LEVEL )
txcounter++;
if((event & CY_SCB_RX_INTR_NOT_EMPTY) == CY_SCB_RX_INTR_NOT_EMPTY)
rxcounter++;
* Function Name: int main(void)
* Summary: This is the main for this code example. This function initializes
* the BSP, creates the tft-task and starts the scheduler.
* Parameters:
* None
* Return:
* int
cy_rslt_t result;
#if defined (CY_DEVICE_SECURE)
cyhal_wdt_t wdt_obj;
/* Clear watchdog timer so that it doesn't trigger a reset */
result = cyhal_wdt_init(&wdt_obj, cyhal_wdt_get_max_timeout_ms());
CY_ASSERT(CY_RSLT_SUCCESS == result);
cyhal_wdt_free(&wdt_obj);
#endif
/* This enables RTOS aware debugging in OpenOCD */
uxTopUsedPriority = configMAX_PRIORITIES - 1 ;
/* Initialize the device and board peripherals */
result = cybsp_init();
CY_ASSERT(result == CY_RSLT_SUCCESS);
/* To avoid compiler warning */
(void)result;
__enable_irq();
/* Create the TFT task */
xTaskCreate(uart_task, "UARTTask", UART_TASK_STACK_SIZE,
NULL, UART_TASK_PRIORITY, NULL);
/* Start the FreeRTOS scheduler. */
vTaskStartScheduler();
/* Should never get here. */
CY_ASSERT(0);
void uart_task(void *arg)
/* Initialize the SCB block to use the debug UART port */
Cy_SCB_UART_Init(DEBUG_UART_HW, &DEBUG_UART_config, &uart_context);
const cy_stc_sysint_t uartIntrConfig =
.intrsrc=DEBUG_UART_IRQ,
.intrPriority = 3UL,
(void) Cy_SysInt_Init(&uartIntrConfig, &UART_Isr);
NVIC_EnableIRQ(DEBUG_UART_IRQ);
Cy_SCB_UART_RegisterCallback(DEBUG_UART_HW, (cy_cb_scb_uart_handle_events_t)HandleEventsUart, &uart_context);
Cy_SCB_SetRxInterruptMask(DEBUG_UART_HW, CY_SCB_RX_INTR_NOT_EMPTY);
/* Enabling the SCB block for UART operation */
Cy_SCB_UART_Enable(DEBUG_UART_HW);
/* \x1b[2J\x1b[;H - ANSI ESC sequence for clear screen */
sprintf(txBuffer, "\x1b[2J\x1b[;H");
Cy_SCB_UART_Transmit(DEBUG_UART_HW, txBuffer, 12,&uart_context);
while((Cy_SCB_UART_GetTransmitStatus(DEBUG_UART_HW,&uart_context) & CY_SCB_UART_TRANSMIT_ACTIVE) != 0){}
sprintf(txBuffer, "****************** FreeRTOS UART Example ****************** \r\n");
Cy_SCB_UART_Transmit(DEBUG_UART_HW, txBuffer, strcspn(txBuffer,"\r\n")+2,&uart_context);
for(;;)
sprintf(txBuffer, "Tx = %d\tRx = %d\r\n", txcounter, rxcounter);
Cy_SCB_UART_Receive(DEBUG_UART_HW, rxBuffer, 1,&uart_context);
while((Cy_SCB_UART_GetReceiveStatus (DEBUG_UART_HW,&uart_context) & CY_SCB_UART_RECEIVE_ACTIVE) != 0){}
/* [] END OF FILE */
Kindly let me know when there are any further issues.
Bhamy Narasimha Shenoy
Hi @Ramya1811 ,
While using FreeRTOS , for hardware interrupts to be in processed the Cy_SCB_UART_Transmit function is to be called inside the tasks. Also check if the transmit complete interrupt is enabled properly. Can you please share the basic UART FreeRTOS project?
Here's what I put together between the Cypress and FreeRTOS tutorials. Note: For my purposes, I do not allow the "bottom half" to block forever. It times out periodically, at which time I take care of some book keeping. Hope it helps.
#include "project.h"
#include "timers.h"
#include "semphr.h"
#include "datalogger.h"
#include "timers.h"
#include <stdio.h>
void uartTask(void *arg);
static TaskHandle_t uartTaskHandle = NULL;
// UART interrupt service handler.
// https://www.freertos.org/RTOS_Task_Notification_As_Counting_Semaphore.html
static void UART_Isr()
BaseType_t xHigherPriorityTaskWoken;
// Disable and clear the interrupt.
Cy_SCB_SetRxInterruptMask(UART_HW, 0);
Cy_SCB_ClearRxInterrupt(UART_HW, CY_SCB_RX_INTR_NOT_EMPTY);
NVIC_ClearPendingIRQ((IRQn_Type) UART_SCB_IRQ_cfg.intrSrc);
/* xHigherPriorityTaskWoken must be initialised to pdFALSE.
** If calling vTaskNotifyGiveFromISR() unblocks the handling
** task, and the priority of the handling task is higher than
** the priority of the currently running task, then
** xHigherPriorityTaskWoken will be automatically set to pdTRUE.
xHigherPriorityTaskWoken = pdFALSE;
/* Unblock the handling task so the task can perform
** any processing necessitated by the interrupt. xHandlingTask
** is the task's handle, which was obtained when the task was
** created. vTaskNotifyGiveFromISR() also increments
** the receiving task's notification value.
vTaskNotifyGiveFromISR(uartTaskHandle, &xHigherPriorityTaskWoken);
/* Force a context switch if xHigherPriorityTaskWoken is now
** set to pdTRUE. The macro used to do this is dependent on
** the port and may be called portEND_SWITCHING_ISR.
portYIELD_FROM_ISR(xHigherPriorityTaskWoken);
void uartTask(void *arg) {
(void) arg; // Turn off compiler warning about unused argument.
uartTaskHandle = xTaskGetCurrentTaskHandle();
// Configure interrupt handler.
(void) Cy_SysInt_Init(&UART_SCB_IRQ_cfg, &UART_Isr); // Installs ISR into CM4 vector table.
NVIC_EnableIRQ((IRQn_Type) UART_SCB_IRQ_cfg.intrSrc); // Turns on interrupt handling.
Cy_SCB_SetRxInterruptMask(UART_HW, CY_SCB_RX_INTR_NOT_EMPTY); // Interrupt when RX buffer is not empty.
const TickType_t xBlockTime = pdMS_TO_TICKS(500);
puts("Started UART task\r");
while (1) {
/* Block to wait for a notification. Here the RTOS
** task notification is being used as a counting semaphore.
** The task's notification value is incremented each time
** the ISR calls vTaskNotifyGiveFromISR(), and decremented
** each time the RTOS task calls ulTaskNotifyTake() - so in
** effect holds a count of the number of outstanding interrupts.
** The first parameter is set to pdFALSE, so the notification
** value is only decremented and not cleared to zero, and one
** deferred interrupt event is processed at a time. See
** example 2 for a more pragmatic approach.
** PAB: We have to use ulTaskNotifyTake ("Example 1" in the
** link) because ulTaskNotifyTakeIndexed requires FreeRTOS
** 10.4 while PSoC Creator only supplies 10.3. However, the
** FIFO has the count, so we can pass pdTRUE as the first
** parameter.
uint32_t ulNotifiedValue = ulTaskNotifyTake(pdFALSE, xBlockTime);
if (ulNotifiedValue == 0) {
// No interrupt.
continue;
// Presumably 'num in fifo' should match ulNotifiedValue. Process
// whatever's in the UART FIFO.
printf("uartTask: %d chars in fifo\r\n", Cy_SCB_UART_GetNumInRxFifo(UART_HW));
if (Cy_SCB_UART_GetNumInRxFifo(UART_HW) > 0) {
uint32_t c;
while ((c = Cy_SCB_UART_Get(UART_HW)) != CY_SCB_UART_RX_NO_DATA)
// My code to copy the characters out of the UART
Cy_SCB_UART_ClearRxFifo(UART_HW);
// After processing all RX_FIFO data, re-enable interrupt.
Hi @pblemel ,
#include "cy_pdl.h"
#include "cyhal.h"
#include "cybsp.h"
#include "task.h"
#include <stdio.h>
#include <string.h>
* Macros
* Global Variables
char txBuffer[100];
char rxBuffer[5];
int txcounter = 0;
int rxcounter = 0;
void UART_Isr(void)
txcounter++;
rxcounter++;
* Parameters:
* None
* Return:
* int
cy_rslt_t result;
#endif
(void)result;
__enable_irq();
CY_ASSERT(0);
for(;;)
Hi @Bhamy ,
I have tried the code that you have mentioned above but still I am facing the same issue . It shows transmit is success but the data is not transferred and the interrupt is also not being called while transmitting .
Hi @Ramya1811 ,
Can you please share your Modustoolbox project to check it in my setup?
Hi @Ramya1811 ,
Please enable the peripheral clock for the respective SCB 10 block before using it.
Hi @Ramya1811 ,
As mentioned above when the clock were enabled to the SCB10 the interrupts started working in my setup.
Add the below code:
Cy_SysClk_PeriphDisableDivider(CY_SYSCLK_DIV_8_BIT, 1U);
Cy_SysClk_PeriphSetDivider(CY_SYSCLK_DIV_8_BIT, 1U, 108U);
Cy_SysClk_PeriphEnableDivider(CY_SYSCLK_DIV_8_BIT, 1U);
Cy_SysClk_PeriphAssignDivider(PCLK_SCB10_CLOCK, CY_SYSCLK_DIV_8_BIT, 1U);
(void) Cy_SCB_UART_Init(SCB10, &scb_10_config, &g_SCB10_suartContext);
Kindly verify it and let me know if you have further issues.
Hi @pblemel ,
Did you get chance to review the previous response? Kindly let me know if you need any further support on this topic.
Hi Bhamy,
This question was posted by @Ramya1811. I provided a some code based on a FreeRTOS blog post that's working for me in reply. I did find your post informative and appreciate that you took the time to provide code. I hope that Ramya found it as informative as I did.
Thanks & Regards
Hi @pblemel,
Sorry for confusing with the names. Thank you for providing the code snippet. I appreciate you for spending time on providing informative response .
Hi @Ramya1811 ,
Did you get chance to try the solution mentioned in my response?
https://community.infineon.com/t5/PSoC-6/UART-interrupt-in-FreeRTOS-using-PDL/m-p/398475#M15487
