AlAl_1520441
5 replies posted 5 questions asked First reply posted
On paper, it seems that PSOC6 is eligible for receiving TinyML framework. But I could not find any implementation out there. Is there any port of TinyML on PSOC available or is there any vision that Cypress port it onto PSOC?
DheerajK_81
Hello @AlAl_1520441 ,
Adding to @RodolfoGL 's comment, you can check this link for updates: https://www.cypress.com/products/modustoolbox/machine-learning
Dheeraj
RodolfoGL
250 sign-ins 5 comments on KBA First comment on KBA
Hello, we are planning to launch a Machine Learning solution with PSoC 6 soon. You can contact your Cypress/Infineon representative to try getting an early release.  Please be ready to provide information about your application and opportunity size.
Hi RodolfoGL,
Do you know when approximately they will launch? I have been using PSoC6 extensively and recently ML has become a need due to which external boards are being attached for inferencing. Also, which source library for models is being considered (Tensorflow or Pytorch)?
DheerajK_81
Dheeraj
RodolfoGL
The solution is ready and available for some key customers (not to the broad market). Please go to https://www.cypress.com/products/modustoolbox/machine-learning and ask for an early access.
SaSu_4784816
First reply posted First like given Welcome!
I'm currently facing an error:
fatal error: cy_ml_inference.h: No such file or directory
I couldn't find the cy_ml_inference file anywhere. This happend while using both ModusToolbox 2.2.0 and ModusToolbox 2.3.0  on windows with CY8CKIT-062-WIFI-BT. Please help.
RodolfoGL
To use our Machine Learning solution, you need to install the ModusToolbo 2.2.3 patch. This patch is not publicly available. You need to contact our team to get an early access.
http://go.cypress.com/modustoolbox-ml
Please fill up the form above and someone will contact you.
