FeCh_4628961
Hi all!
Trying to figure this error I get when I program the (CM0p) :
"There was an error while programming the device: PSoC Programmer reported error (100 - EraseAll API returned: Error code 0x76AFF110: Unknown SROM status code)"
I am programming the Psoc63 CY8C6347FMI-BLD53 using the MiniProg4 on Psoc Creator 4.2.
Does anyone have suggestion as to what could cause this error?
Thank you in advance!
Felix
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hi fech_4628961​,
Please provide details regarding your setup which will help us debug your issue.
Can you please check if -
1. the schematic meets the hardware design guidelines. Please refer to the PSoC 6 Hardware Design Considerations and PSoC 6 MCU: CY8C63x6, CY8C63x7 Datasheet
2. all the Programmer Parameters and the Programmer Characteristics of PSoC Programmer are correct
3. the connections to the device from the MiniProg 4 is correct and the cable is short
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi fech_4628961​,
Rakshith M B
Thanks and Regards,
Rakshith M B
