The demo PSCO62 BLE multi_beacon can not run
ufoazst
First reply posted First question asked 5 sign-ins
 I make a new project demo like below, the BLE Multi Beacon.
when it build ,burn it in to CY8CPROTO-062-4343W and run ,the result is not correct, the Tera terminal display information like this .
Bluetooth Stack Initialization Successful
Bluetooth Enabled
Local Bluetooth Address: 43:43:A1:12:1F:AC
Multiple ADV started.
Use a scanner to scan for ADV packets.
Multi ADV Set Data Event Status: FAILED
Multi ADV Set Param Event Status: FAILED
Multi ADV Start Event Status: FAILED
  Do you know what make it failed, and i didn't changed any thing in this demo.
Tushar_b
100 replies posted First like given 25 solutions authored
CYW4343W controller doesn’t support multi advertisements at this time.
Please refer the following thread for reference.
https://community.infineon.com/t5/ModusToolbox-General/FYI-AnyCloud-BLE-Multi-Beacon-not-working-wit...
Tushar
ufoazst
some time when launches the program it may display  ran after reset and before halot.....
Tushar_b
Tushar
Len_CONSULTRON
Level 9
Level 9
ufoazst,
Maybe this link to a forum page might help:  PSoC6-BLE-Beacon-and-Scanner-Creator-projects
I create this project to learn and help others with BLE advertisement beacon generating and monitoring (scanner).
I believe the Beacon has the ability to perform multi-advertisements. (it been a while since I've visited this code).
Give it a look/try.
Len
