I make a new project demo like below, the BLE Multi Beacon.
when it build ,burn it in to CY8CPROTO-062-4343W and run ,the result is not correct, the Tera terminal display information like this .
Bluetooth Stack Initialization Successful
Bluetooth Enabled
Local Bluetooth Address: 43:43:A1:12:1F:AC
Multiple ADV started.
Use a scanner to scan for ADV packets.
Multi ADV Set Data Event Status: FAILED
Multi ADV Set Param Event Status: FAILED
Multi ADV Start Event Status: FAILED
Do you know what make it failed, and i didn't changed any thing in this demo.
some time when launches the program it may display ran after reset and before halot.....
CYW4343W controller doesn’t support multi advertisements at this time.
Please refer the following thread for reference.
Tushar
ufoazst,
Maybe this link to a forum page might help: PSoC6-BLE-Beacon-and-Scanner-Creator-projects
I create this project to learn and help others with BLE advertisement beacon generating and monitoring (scanner).
I believe the Beacon has the ability to perform multi-advertisements. (it been a while since I've visited this code).
Give it a look/try.
