hata_3396041
Level 4
Level 4
First solution authored First like received 50 questions asked
Hello
The contents of the HEX file are different
The size of the HEX file created by the same method in PSoC Creator 4.2 depends on the created PC.
Is this a difference due to Metadata?
Best Regards
Hayato
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hello Hayato-san,
Can you please compare the 2 hex files or share the 2 hex files on this thread?
I created a PSoC 6 Hello World code example and asked one of my colleagues to do the same. I could not find any difference in the hex files when I compared the two files.
Also, you can check if the differences are in the metadata section -
Hope this helps,
Thanks and Regards,
Rakshith M B
Rakshith
Hello Hayato-san,
Hope this helps,
Thanks and Regards,
Rakshith M B
