SysTick not working for PSoC61 device
Psoc_students
First like given First like received First solution authored
I am attempting to use Systick on PSoc61(CY8C6144AZI-S4F) because I want the value in milliseconds. However, the interrupt is not occurring in the interrupt function set with Cy_SysTick_SetCallback(0, systick_isr), and the value of 'tick' is not increasing.
The same code runs without issues when executed on the [CY8CPROTO-063-BLE] kit.
The procedure for creating a project in ModusToolbox is as follows:
  •  Turn on CLK_TIMER in Device Configure.
  • Add the following content to main.c
Can you guys please tell me, what can be the issue?
Psoc_students
Hello @ADSW ,
Thank you for  Advice.
Systick clock source is enabled.
And, Cy_SysTick_Init() include  Cy_SysTick_Enable() function.
But, I solve this problem.
I changed clock source.
CY_SYSTICK_CLOCK_SOURCE_CLK_TIMER → CY_SYSTICK_CLOCK_SOURCE_CLK_CPU
Thank you
Psoc students
ADSW
250 sign-ins 50 solutions authored 25 likes received
Hello @Psoc_students ,
Please ensure the clock source for SysTick is enabled.
After initialize the SysTick ( set the clock source and interval ),  set the callback then enable the SysTick by calling Cy_SysTick_Enable() function.
Warm regards
Andri
Psoc_students
Hello @ADSW ,
Thank you
Psoc students
ADSW
Thanks for your update.
Actually, You can choose the source clock based on which clock is active ( enabled ); between them
And set the interval based on the clock source value and desired time interval.
Then I will close this thread,
Thanks & regards
Andri
