snortman-kcl
First question asked Welcome!
I have implemented an SPI master using the PSOC Creator tool, v4.4, PDL 3.1.4
The SPI master works intermittently; sometimes when I call the Cy_SCB_SPI_Transfer function, the processor is stuck in the
Cy_SysLib_ProcessingFault()
Function.
Are there any known issues with the SPI master component?
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @snortman-kcl,
You can check out the component datasheet for the common issues faced - https://www.cypress.com/file/385921/download
Can you share your project so that it becomes easier to debug?
Nikhil
ncbs
Hi @snortman-kcl,
The thread was locked due to inactivity for a long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Nikhil
