Hello!
I'm trying to perform two DMA transfers at the same time. So I want to make use of the two different DMA controllers. Is there a way to configure the DMA controller to use for specific tranfer in PSoC Creator?
So far I'm only able to achieve this by manually editing the generated header file.
Grettings!
- dma
- psoc 6 dma
You can add a control file in your project, then write the following line:
attribute placement_force of \MyDMA:DW\ : label is "DMA(0,channel_id)";
Substitute MyDMA with the name assigned to the DMA component. channel_id is calculated as:
channel_id = C * channels_per_controller + N
If you are using PSoC 6-1M, you can set channel_id = 16. It will be placed in the first channel of DW1.
Hi
Can you please elaborate on the requirement? Please share the project if possible
Thanks and regards
Harigovind
