- Email to a Friend
I have a question regarding "Alarm system" below.
https://www.infineon.com/cms/jp/applications/solutions/sensor-solutions/alarm-system/?redirId=197381
Does this solution provide the AI algorithm for the home security solution by free?
In this case, is it possible to work only IFX Psoc, MEMS MIC and Pressure sensor without QuickLogic?
Does IFX have a plan to provide it for the automotive algorithm of thie solution?
N.N
PSoC 6 MCU
- Email to a Friend
Hi h_nakamura,
Sorry for the delayed response.
01. No, the solution will charge for SW IP developed by IFX. It’s a full system solution.
02. I think you are confused in between microIAS and SAS(Smart Alarm System). The Quicklogic design is only for Flex’s SiP module. SAS is battery-operated solution, which is a power optimized based on an acoustic event detector, sensor fusion of IM73A135 and DPS310 and also a PSoC6.
03. Infineon supports aftermarket automotive applications. The parts are not AEQ-100 certifiable so this will not work for the automotive OEM market.
Thanks and regards,
Sunil.
- Email to a Friend
- Email to a Friend
Hi h_nakamura,
Thanks and regards,
Sunil.
