I have a few questions about two-processor PSoCs.
If I declare a global variable in a header file inside shared-code folder, how will this be compiled?
Will this get compiled as two variables, one for each core? Or will this be compiled as a shared memory location?
If the first, how should I declare shared memory?
And the last question, how will volatile keyword behave in two-processor environment? I used to declare variable as volatile, when it may be accessed from multiple ISRs and/or non-interrupt code. Does this mean that all shared memory should be volatile?
Stanislav
Hello Stanislav,
The draft application note in another thread addresses the shared memory issue. There is an associated code example which I will also publish. Please let me know if these address your needs.
Mark Ainsworth
