I'm trying to program a hex file to CY8C6136 using Segger J-flash (V7.66a).
Q1. Which one should I choose from the list below in the Target Device Settings?
Q2. What is the difference between CY8C6xx6_CM4 and CY8C6xx6_CM4_sect256KB?
Q3. Should I only program to the M4 because it's single core?
Thanks and Regards,
YS
Hi @YongseokJeon,
1]You can choose either CY8C6xx6_CM4 or CY8C6xx6_CM4_sect256KB from the list below in the Target Device Settings.
Both works. Please refer to the screenshot:-
2]The main difference between CY8C6xx6_CM4 and CY8C6xx6_CM4_sect256KB is that CY8C6xx6_CM4 has Erase Sector Size of 512 B and CY8C6xx6_CM4_sect256KB has Erase Sector Size of 256 KB.
3]Please program in CM4 because it's single-core. Please refer to the screenshot below:-
Warm Regards,
Gautami J
Hi @YongseokJeon,
Warm Regards,
Gautami J
Hi, Gautami.
Thanks for your help.
YS
Hi @YongseokJeon ,
Glad your query has been resolved.
Please feel free to post any queries or issues you may have on Infineon products in the community and we will be happy to help.
Warm Regards,
Gautami J
