PSoC™ 6 Forum Discussions
GeEd_1216226
Level 4
Level 4
25 replies posted 10 replies posted 5 replies posted
Does anyone have a sample project that runs this OLED using I2C?  Not interested in setting as a task.  Any help appreciated.  Tried to take a PSoC 4 example and transfer that to PSoC 6 but it went pear-shaped.  TIA.
Hi giio_4660191​,
Please refer to this thread and let me know if it helps with your query - How to interface an SSD 1306 OLED?
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
RyanZhao
750 replies posted 100 sign-ins 100 likes received
Hi Geoff,
I wonder about error details you met when tried porting the PSoC4 example to PSoC6? I2C can work or not?
I remember there is an initialization command sequence for the OLED in the example (or in its datasheet). Does it work on PSoC6? I just want to know it is hardware problem or software problem.
Ryan
Ryan, Thanks for your response.  I have started a new PSoC6 project and it compiles.  I have transposed the commands to the PSoC6  but do not have any initialization of the OLED.  Alan Hawse has done a project using FREETOS but has not shared the entire code, which could be helpful as a starting point but I am not experienced with FREEtoS and already have a large Lora Mesh networking system running...I just want a small display on each unit so I can see activity in my mesh trials.
I cannot even measure the SCL clock using a CRO, so I think I have a conceptual issue with the Slave I2C process.  I have also used the 8x8 library set for the OLED.
Just wanted to know if anyone has some short working code snippet I can use given that normally a display is not that hard to get working.
Ryan, I found the issue.....the SSD1306 modules were the SPI/I2C modules, I was provided with the wrong ones and did not realize because they had SDA and SCL written on them.  Waiting for some proper modules and I will report back about the project.  I was not prepared to use the SPI/I2C modules because there is no appropriate documentation.
Hi Ryan,
I managed to get it working on the PSoC 6.  I used some code from an old example of Alan Hayes.  Not real pretty yet but at least I have junk on the screen now.  Happy to share the basic PSoC 6 file for the PSoC6 Kit 062, but first I might add some pretty graphics examples to mirror the various other examples so that there is plenty of demo there.
Geoff
I am interested in your library. Can you please share it.
hello everyone ,
I am interested  too for a library to manage  oled with Psoc 6
did you have it?
Can you share it?
Thanks a lot
Hi giio_4660191​,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
