When I run the program in MODUS toolbox I get this type of error.What to do? AND some time I am also getting BAUDRATE error
Programming target device ...
Found serial port : COM4
Downloading FW ...
Failed to execute DownloadMinidriver command
Download failed
If the serial port was not detected, make sure no other program such as ClientControl has the port open.
If you have issues downloading to the kit, follow the steps below:
Press and hold the 'Recover' button on the kit.
Press and hold the 'Reset' button on the kit.
Release the 'Reset' button.
After one second, release the 'Recover' button.
make[1]: *** [../mtb_shared/wiced_btsdk/dev-kit/baselib/20706A2/release-v3.1.0/COMPONENT_20706A2/make/recipe/program.mk:102: qprogram] Error 1
make: *** [../mtb_shared/core-make/release-v1.8.0/make/core/main.mk:426: secondstage_build] Error 2
PSoC 6 MCU
Have you recovered the device properly as in the error message?
Also, could you please try connect the HCI UART CTS pin to ground using fly-wires and try programming again?
-Dheeraj.P.K
-Dheeraj.P.K
FYI.
