Does the CYBLE-416045-02 contain the SMIF block? I can put the component into my project and PSoC Creator doesn't say that it won't work with the selected device, but when I try to build, I get an error:
Error: fit.M0059: FFB and IO placement failed: Failed to find a valid placement for \SMIF:spi_clk(0)\. (App=cydsfit)
You will find there are no proper pins allocated for SMIF.
The pins dedicated for SMIF block are not exposed to the module pinout of CYBLE-416045-02. Therefore, the SMIF is not available for user.
