Restart both CPU CM0 and CM4 , programmatically.
MSS
5 likes given 50 sign-ins 10 replies posted
I have DFU running in CM0 and  Application running in CM4.
I want to restart the PSOC , both cores, How to do it programmatically.
Madhav
Ekta
750 replies posted First like given 250 solutions authored
You cannot reset CM0+ core from CM4, however, if you call NVIC_SystemReset from CM4 core it will reset only the CM4.
Calling NVIC_SystemReset from CM0+ will reset the entire system.
MSS
@Jayden
Thanks for the answer.
I forgot to mention , I am using   Modus toolbox. Which header file to include for the above code?
I believe the steps you gave may work with Psoc Creator.
Can you tell me steps for Modus Toolbox?
Madhav
Ekta
Hi @MSS
I guess by restart you mean reset.
If you want to reset only CM4 core, then it is possible to do so using the PDL API call Cy_SysLib_SoftResetCM4()
If you want to reset both CM0+ core and CM4 core then you would need to call NVIC_SystemReset API from CM0+ core. Resetting CM0p causes the CM4 also to be reset because it enables the CM4 processor.
Best Regards
Ekta
MSS
Thanks for the reply.
I am confused.
My requirement is "can  code running in CM4 core, reset CM0 or CM4 " if yes how?
Madhav
Ekta
