MaPe_4795006
10 sign-ins 5 sign-ins First reply posted
Hello!
I'm building  a product with a similar flash memory map layout as this example, except I will have two "user" applications. So in CM4 there are applications 0 (bootloader using DFU SDK), user apps 1 and 2.
https://github.com/Infineon/mtb-example-psoc6-dfu-basic
For field upgrades of the user application, I'm creating patch files (.cyacd2 format) using cymcuelftools. When building a patch file, I've defined the flash memory region where this patch is applied in the linker script. Do I have to build two patch files, one for each possible flash memory region? Is there a way to build relocatable images/patches?
Markus
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi Markus,
You can find more information on patching images in the below document
https://www.cypress.com/file/493001/download
Alakananda
Alakananda_BG
Hi Markus,
Alakananda
