Hello.
I'm looking for BLE sample project of PSoC Creator using CYBLE-416045-EVAL.
I'm thinking of using two CYBLE-416045s and communicating as Central and Peripheral respectively.
The data to be communicated by connecting CYBLE-416045s is about 8 bytes of sensor data.
Is there PSoC Creator BLE sample project(both Central and Peripheral) for PSoC6 similar to the above?
It helps if infineon has simple project that just communicates a few bytes of data.
Best Regards.
YuMa
ispn:40211:1:0
l1:314:1:0
PSoC6MCU
Please refer to the "CE222046–PSoC 6 BLE Throughput Measurement" code example from the PSoC Creator. It has two projects 'CE222046_GATT_In' and 'CE222046_GATT_Out'. The CE222046_GATT_In is GAP Central device and CE222046_GATT_Out is a GAP Peripheral.
P Yugandhar.
P Yugandhar.
Yugandhar-san.
Thank you for your response.
I understand.
Best Regards.
YuMa
