Sep 30, 2022
12:13 AM
Sep 30, 2022
12:13 AM
Using the CY8CPROTO-062-4343W PSOC6 WIFI-BT PROTOTYPING KIT,from EEPROM, we are attempting to read and write data. By utilizing the built-in code for Emulated_eeprom, we can write data to EEPROM. We can read the data as it is being written, but if we reset the board and attempt to read the data at a different place in the code, we are unable to do so. Do we need to add an external EEPROM to the board or is it possible to retrieve the EEPROM data from a location other than the one where we wrote it?
Thank you
11:36 PM
Oct 02, 2022
11:36 PM
Hi @SURYASUNDAR ,
Can you let us know from what location you are trying to read the code?
Is it allocated to eeprom only?
If it is, it should be possible to read the data
Alakananda
11:36 PM
Oct 02, 2022
11:36 PM
Hi @SURYASUNDAR ,
Alakananda
