RTC can not wakeup M0+
JeHa_3912621
25 replies posted 10 replies posted 10 questions asked
Used  Demo code "Custom_TickTimer_RTC01",    if  run on  M0+,   can not  wakeup deepsleep mode.  if  the  M0+  not in deepsleep mode, the rtc  alarm can run 3s loops.
JeHa_3912621
The problem has already been solved。
ARM  CM0+ Vector(3~7)  can  wakeup  deepsleep.   Change the  RTC_M0_RTC_IRQ from 15 to 6,  The problem has already been solved.
JeHa_3912621
