Apr 26, 2022
10:50 PM
Apr 26, 2022
10:50 PM
Hello, I am using the Psoc6 board and have a question about RTC.
I am implementing RTC using a HAL driver.
I know that the source clock of RTC is CLK_LF.
So let's decide on one scenario.
I will set up PILO in CLK_LF to use RTC.
By the way, PILO's error rate is about +-10%.
So I will use PILO by trimming with IMO.
If so, do I need to reset the RTC if I want to use PILO that went through Trim?
If i want to use the Trimmed Clock, I wonder how to write the code.
I know the trimming process well and I would like to ask you about how to use the watch after trimming.
Thankyou for your apply
05:56 PM
Apr 27, 2022
05:56 PM
For example, after trimming in this way, should I write an RTC action code?
