inja_4756821
Distributor
25 sign-ins First like received First solution authored
Dear experts,
I have a question regarding OPENOCD CLI.
All other functions have been implemented,
but the part related to External Memory Erase & Programming is not working well.
Can I get help on how to use External serial memory (SMIF)?
The below log is excerpted from cypress programmer.
Warn : Adding extra erase range, 0x18019000 .. 0x1803ffff
Info : [100%] [################################] [ Erasing ]
Info : [100%] [################################] [ Programming ]
Info : wrote 604160 bytes from file C:/firmware1.hex in 8.338982s (70.752 KiB/s)
Info : ** Erasing bank 8 **
Info : Using EraseChip API to erase 'psoc6_smif1_cm0' bank, this may take several minutes...
inja_4756821
Distributor
I Solved the this issue.
Hope this helps someone.
PSoC61 (CM4 Only Version)
1. Internal Flash Erase
openocd -c "set ENABLE_CM0 0; source [find kitprog3.cfg]; source [find psoc6_internal.cfg]; transport select swd; cmsis_dap_serial 190E03B803260400; init; reset init; psoc6 sflash_restrictions 1; flash probe 0; flash probe 1; flash probe 2; flash probe 3; psoc6 allow_efuse_program off; flash banks; erase_all; shutdown"
2 . Internal Flash Program
openocd -c "set ENABLE_CM0 0; source [find kitprog3.cfg]; source [find psoc6_internal.cfg]; transport select swd; cmsis_dap_serial 190E03B803260400; init; psoc6 sflash_restrictions 1; psoc6 allow_efuse_program off; program d:/firmware.hex verify reset exit"
3. External Flash Program
openocd -c "set ENABLE_CM0 0; source [find kitprog3.cfg]; source [find psoc6_external.cfg]; transport select swd; cmsis_dap_serial 190E03B803260400; init; psoc6 sflash_restrictions 1; psoc6 allow_efuse_program off; program d:/firmware.hex verify reset exit"
BR
IK
LeoMathews
First question asked 500 replies posted 100 solutions authored
Hi @inja_4756821
Can you please refer to this PDF to understand how to use External serial memory (SMIF) and check if this helps? Also, please go through the PSoC 6 Peripheral Driver Library to know more about external memory erase & programming.
Thanks and Regards,
Leo
inja_4756821
Distributor
Hi Leo,
Thank you for reply.
Information on SMIF R/W is already known and applied to the project.
What I want to know is that if you look at the Cypress Programmer, you can Download or Erase to External Flash. Internal works well through OPENOCD Example as shown below.
openocd -s ../scripts -f interface/kitprog3.cfg -f target/psoc6.cfg -c "transport select swd; cmsis_dap_serial 190E03B803260400; psoc6 sflash_restrictions 1; init; reset init; program c:/firmware.hex verify reset exit"
I would like to know the command for downloading to external memory.
openocd -s ../scripts -f interface/kitprog3.cfg -f target/psoc6.cfg -c "?????????????; exit"
inja_4756821
Distributor
BR
IK
