Hello I using Psoc6 Pioneer Kit and I'm using the
"SCB_UART_Transmit_and_Recieve_using_DMA" example to implement DMA.
In the example, the buffer size is set to 1, and it is sent as soon as it receives 1 Byte.
I want to collect several Bytes and receive them at once, not one at a time.
Additionally, I would like to send an array with multiple bytes at once through DMA.
Is there a way?
Thankyou for your reply.
You can take a look at this thread - https://community.infineon.com/t5/PSoC-6/PSOC6-DMA-block-selection-for-SPI/m-p/285427 - where DMA is implemented for multi-byte transfer using an SPI block. The same can be implemented for UART as well.
Hari
Hari
