GePa_4776901
10 sign-ins 5 questions asked 5 sign-ins
I'm using CY8CPROTO-062-4343W. I looked at the ADC_basic example that reads two channels asynchronously (one single ended and one diff).
I would like to incorporate a reading of the internal Temperature Sensor as a third channel.
The example uses HAL drivers found here: Hardware Abstraction Layer (HAL)
but, I can't find how to configure a channel to read from the internal temperature sensor.
Is there a way to do it using the same HAL library? or an example that reads the temperature sensor?
Thanks!
Vasanth
As HAL is targeted a large range of devices from different families this is not handled in HAL. This can be done using PDL. There is no example in ModusToolBox. Could you please checkout CE220974. Here ADC Die temp is measurement is done using PDL APIs.
Vasanth
Vasanth
Vasanth
