Why the I2C slave interrupt sources must be enable for the Psoc6 SCB master I2C mode read or write operation?Show as the flow pictures:
Which interrupt event will be happened for the every step of i2c master operation?
PSoC 6 MCU
Hi @Dave_Long
In case of PSoC 6 it is possible to set I2C mode as master-slave. I guess in this mode it will be required to disable the slave interrupts before a master read is done and enable them after the master write is completed.
" Which interrupt event will be happened for the every step of i2c master operation?"
You can refer to the PDL API Reference Library: https://cypresssemiconductorco.github.io/psoc6pdl/pdl_api_reference_manual/html/group__group__scb__i... to know the I2C events that are supported. Each event is encoded in a separate bit, and therefore it is possible to notify about multiple events.
It is possible to Registers a callback function that notifies that I2C Callback Events occurred in the Cy_SCB_I2C_Interrupt using the Cy_SCB_I2C_RegisterEventCallback() function
You can refer to the code snippets provided in the PDL to configure Interrupts: https://cypresssemiconductorco.github.io/psoc6pdl/pdl_api_reference_manual/html/group__group__scb__i...
Please feel free to update for any clarifications.
Thanks and Regards
Ekta
Hi @Dave_Long
Thanks and Regards
Ekta
